Discuss Fan puller that will last. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gazzt
Does anyone know where I could get a decent fan puller, other than the universal puller with the Allen key grub screws. Thanks.
Riello fan's are stubborn.
Will the finger ones fit ?
I discovered my bearing puller also works as a Riello fan puller.
A tip I learnt is not to pull the fan, but turn it on motor spindle to screw it off.
You need to hold the other end of motor (oil pump drive end) to prevent it spinning.
This sort of puller is better as the arms are narrow. I got mine off ebay for about ÂŁ8. Just take the screws out if they get in the way
Reply to Fan puller that will last. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
