Discuss Exposed shower bracket surface mount? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. macka09
    macka09 Plumber GSR
    hi guys. What brackets are you guys using for a retro fit mixer shower? A lot of what I’m finding is for behind the tiles but that’s not an option on this occasion??
  2. townfanjon
    If you mean bar mixer , I use some screwfix sell , around £15 ish .
  3. ShaunCorbs
    Bristan own surface kit
  4. JCplumb
    JCplumb Plumber
    I use one my merchants do, like the picture but the back nuts are recessed into the bracket so can be fitted flush with tiles.
    Doh!
    Just read the OP properly.. Retro fit you say? Hmmm, maybe not one of these then :)
  5. Harvest Fields
    Something like these mate.
  6. Millsy 82
    Millsy 82 Plumber GSR
  7. Harvest Fields
    Apologise for the above post of mine. Not sure that is what you meant.
  8. JCplumb
    JCplumb Plumber
    Pretty much all exposed showers have their own bracket that fixes to the wall then the shower fits into that. If you get the right shower you won't need any other fixings. (Not bar mixers obvs)
  9. macka09
    macka09 Plumber GSR
    I need a surface mount as the pipe work will not be in the wall. It’s going to be chrome pipe coming down from the loft. Harvest Fields seems to have the right idea
  10. Harvest Fields
    So it is what I have put then. :p:p
  11. JCplumb
    JCplumb Plumber
    Aah so you're going for a bar mixer? Deffo go with what Harvest suggested.
    I'm a bit slow tonight...
    • Funny Funny x 1
  12. scott_d
    scott_d Plumber GSR Top Contributor!!
    Mira and Bristan sell showers that you can turn the inlet elbows to run exposed pipes
Loading...
Similar Threads - Exposed shower bracket Forum Date
Exposed cable in the shower. Is it safe? Bathrooms, Showers and Wetrooms Mar 23, 2019
Exposed Thermostatic Shower Mixer with 22mm inlets? Bathrooms, Showers and Wetrooms Mar 8, 2019
  1. exposed shower bracket
  2. surface mount plumbing in shower
