Discuss Expansion tank in un-vented system... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
macdaddy2x
I have an unvented hot water/central heating system in my home. I recently went round and bled all the radiators, because of this the pressure in the expansion tank dropped to 0. I connected the filling line and filled it back up so it was at 1.5 bar. Is it ok to do this? What should the pressure in the expansion tank be? I guess eventually I will lose the air bubble by doing this... how do I make sure this doesn't happen/get it back?
Thanks in advance.
you should pressure it to 1.5 bar nothing will really happen atall , does it keep going to zero?
Since I have charged it back up it has stayed at 1.5 bar, it only went to zero when I was bleeding the rads.
Is that normal?
Thanks for the reply by the way.
Is that normal?
yeah that's normal but do keep an eye out for pressure loss it can be a leak/ or faulty discharge(check pipe outside) but a bled radiator is a leak of sorts and the pressure drops
Guys... thanks very much for taking the time to answer my questions.
Reply to Expansion tank in un-vented system... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
