Discuss Electrician wiring heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gary80gas
I had a debate with an electrician about correct wiring of regular Worcester boilers. I told him it needed to be wired to give the boiler control of when the pump comes on. This would mean up dating cables. He said using the original wiring just a switch line to activate both at same time was just as good and its how a lot of these boilers are wired. What do you think?
They do work but not recommended it’s advised so no problem
The magic word could and tbh don’t see they would invalidate
Reply to Electrician wiring heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I just installed second zone onto my ideal independent c35 original I had one hive thermostat now I added two two port valves ( with Bypass) and two hive thermostat V3 it wired into a wiring centre looking at the wiring on the boiler shall I put back the room stat/ timer loop back in as...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi Fellow Engineers I've attached a wiring diagram I've just completed, I wanted to make sure I've got it correct. Looking to install 2 Nest thermostats to a Worcester combi boiler. 1 Zone is radiators and the other is UFH, with pump on manifold Would be grateful to receive feedback. Thanks
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
Vaillant ecoFIT 415 open vent heat only boiler. For wiring the boiler and pump, should I use the 3-way wire switch" solution OR a "remote switching" solution? The pump and copper tank are situated about 25ft from the boiler. I've been told that the 3-way cable solution doesn't work well with...
