Discuss Durgo/AAV under sink question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bes
Hi there
We moved our kitchen sink, dishwasher, and washing machine during a renovation and as a result have a much longer wastewater pipe now. I have been advised to fit an AAV before I will be issued with a building cert.
I am a bit confused reading about AAVs and I am new to this, but...
It seems there are a few different types, but in order to pass building regs you need to use an A1-rated valve IF you want to have the valve BELOW the sink overflow level (Which I do as I would put it under the kitchen sink so it's easy to get at).
Am I interpreting the rules & regs correctly? Would something like this T'ed off the sink waste do the job?
https://www.NoLinkingToThis/p/flopl...VjLHtCh3VeQ1TEAQYASABEgK_q_D_BwE&gclsrc=aw.ds
Thanks!
Thank you - we actually failed the first inspection based on a couple of little things and this was on the notes the BC gave us so I’d guess I had better do it! I have no idea why either - I am quite new to plumbing. Long story but we fell out with our builder just before he finished the job so I am doing the last bits myself.
So no matter where on the waste pipe I put the AAV (all 3 appliances connect in to the same pipe) so long as it is accessible I am safe from a regs perspective?
Reply to Durgo/AAV under sink question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
