Discuss Dishwasher leaky tap issues. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So we've bought a dishwasher but it requires to be on the cold tap. We've had to buy a Y connector as the washer is also on the cold tap, the washer connection is fine but the dishwasher is a nightmare. Obviously the PTFE tape has probably not been used for its intended purpose but if you can see the pictures the one with the white circle is where it's coming out, it's just spraying so hard obviously due to the pressure but it shouldn't be spraying out like it is. Any ideas why it could be doing this?
could be a few things
is the brass part tight onto the y also no hitting / stopped by the valve part
is there a washer in the end
My suggestion is that if it is coming from the circled bit, the the hose may be damaged.
I’m on about the bit that I have Circled with the black electrical tape.
Oh they're just keeping the waste pipes popping off.. our landlord likes electrical tape, we just added the dishwasher pipe then added more, it works haha.. I'm feeling we probably need to hire an actual plumber for the dishwasher. Was just hoping it was a quick fix
Reply to Dishwasher leaky tap issues. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
