Discuss Disability bathroom in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. plumb_know
    plumb_know Plumber GSR
    Hi Everyone,
    Have a customer who needs a shower room for disabled daughter, i have done wet rooms etc but they would like the commercial type shower room you get in hospitals with the lino type flooring with welded joints which go up the wall.
    Is this something i would need to get a specialist in for, if so can anyone recommend a company in kent??
    The floor area is 3.4m2
  2. Craig Watson
    Craig Watson Plumber GSR
    Don't think it's specialist. We use polyflor when we do disabled bathrooms/wetrooms and a couple local flooring companies round my area supply and install. Just ring around and I'm sure you'll find someone who does it fairly easily.
  3. ShaunCorbs
    Altro flooring you need anti slip pick of colours to choose from
    Defo special
    • Agree Agree x 2
  4. SimonG
    SimonG Trusted Plumber
    Polyflor
  5. Rob Foster
    Rob Foster Top Contributor!!
    Before you put the floor down use sound deadening insulation
    under the floor boards. If It its upstairs that is. The shower can produce a drumming sound and vibration which can be very annoying in the room below.
    centralheatking
  6. snowhead
    snowhead Plumber
    The floor isn't a specialist job but is out of the realms of the average domestic carpet / vinyl layer.
    All Commercial flooring layers will have done it.
    Alto and similar with welded joints is used in commercial food prep areas and kitchens.
    • Like Like x 1
  7. king of pipes
    Altro is the favoured product used in my area cant see it as specialist I did one recently and a local flooring company did the flooring after I had fitted the starter trim and tiled . Kop
  8. Millsy 82
    Millsy 82 Plumber GSR Top Contributor!!
    Round me the they all use altro as well. Most floor layers will fit it as well.
  9. N&C_Dave B
    N&C_Dave B Sponsor
    Vinyl flooring is something that lots of floor layers will be able to do for you, Nicholls and Clarke would be happy to offer any advice that you may need in the selection of products for your clients wetroom.
    • Like Like x 1
  10. CBW1982
    CBW1982 Plumber GSR Top Contributor!!
    The style you are referring to I think is called cap and cove. Usually goes up the wall by 150mm and usually requires specialist equipment to carry out the we led decliners joints.
  11. Craig Watson
    I would hardly call the equipment specialist. It's nothing more than a fancy glue gun :D
  12. ShaunCorbs
    Heat gun
  13. CBW1982
    Fair do’s, I guess I had the wool, pulled over my eyes :oops:
  14. plumb_know
    Thanks everyone, all really helpful as usual :)
  15. WC1
    WC1 Active Member
    True, but if the guy doesn't get the seam quite right you're in a world of pain with callbacks for damp...
    :D
Loading...
Similar Threads - Disability bathroom Forum Date
Bathroom Mixer Tap - Tapping Noise Valves & Taps Saturday at 12:11 PM
Bathroom Basin fitting Plumbing Forum Friday at 11:30 AM
