Currently reading:
Dimplex cylinder
Discuss Dimplex cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Whn1
Hello my favourite people!
Ok dimplex pressurised cylind (similar to megaflow)
the cylinder is direct, in a newish build flat.
130ltr has two immersions, when you switch both both immersions on the water gets hot as it should but the cylinder loses heat very quickly, like if you have a shower the water will be cold again in 4minutes ( no chance of a bath), also if you leave the immersions on continuously it doesn't stay hot.
The homeowner has had the plumber out and the electrician who both claimed to have fixed it but quite clearly didn't know what they were doing or how the system works, the rads are electric and run off a programmer.
Phone this kinda makes sense, thanks guys.
Tony
If they are on econ 7 there will be a relay or a timer
Best thing to do is to either loop a live to the relay or if on a timer. Find the breaker in the board and put a temp supply to it
This is just for testing
There's defo no timer, if she wasn't on econ 7 would that mean that the spur would always be dead?
You should check to see how she's billed. E7 should be stated on it somewhere. If it's all wired up for E7 there will more than likely be 2 separate consumer units. Does she have storage heaters as well?
The timers normally incorporated into the meter, you'll have a 2 tier meter and 4 tails coming out the meter.
Let me take a photo .
Ok that would help, not of the cylinder cupboard though, thats irrelevant, you need to find the source that supplies the spur.
Sent from my iPad using Tapatalk HD
Excuse the quality..
Can you take a picture of the leccy meter, can't really make out much from those photo's other than a split load board, a telephone socket, fused spur and another box which I have no idea what it is!
And yes storage heaters. I may tee off my gas meter at home 15miles away, and run a discrete supply here... Any one fancy pipe sizing that for me..
Use hose pipe. You can get that in long lengths.
I trust your GSR before you attempt this
Are there 2 fuse boxes?
The off peak stuff is usually supplied from a separate box. Check it again at dark o'clock.
Never noticed your pics
I had to search high and low for this bad boy! Hope the photos of some use I had to run from top flat to ground floor in my jim jams!!!
I am here: http://tapatalk.com/map.php?1jn5cy
Is that 6 cables coming out the meter, ie 3 N and 3 L?
If so you need to find another consumer unit as thats the E7 board and will be the source of your lower immersion fused spur.
If you are going to use hose pipe make sure it is yellow then people will know it's for gas !!:wings:
Reply to Dimplex cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
