Discuss Deck Mixer Tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Spiderman
I have a kitchen Deck Mixer Tap which continues to drip water or stay on after usage and the only way I can stop the water coming out is to lift the hot leaver upwards. Can anybody tell me how to fix this problem and what washer needs to be replaced or whether it has a cartridge instead. it dosent matter whether I use the cold or hot tap it will only stop leaking when I lift the hot lever upwards
Hi spiderman. If your deck mixer is quarter turn to put on or off then it's a ceramic dusc cartridge that it needs and there's so many different types n styles with no indication written on them to know which ones you need . Best thing to do is switch water off and remove the insert to have a look . Then scour the Internet in places like this.
Tap Spares
Reply to Deck Mixer Tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
Hello, I have a few mixer taps to install in bathrooms and kitchen. The kitchen tap also has a wondering spray arm capability. On researching something else, i stumbled across people saying that a check valve should be placed on the cold mains feed. How can I tell if the mixer taps/spray arm mix...
Hello, I need some advise, will greatly appreciate if someone can help. My mixer tap is leaking from base want to renew it. However the tap cold/hot water feed is connected via connectors/fittings as shown in attached picture. Can anyone please advise how to disconnect tap from these fittings as...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
