Discuss Corrugated cardboard wall panels in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. YorkshireDave
    YorkshireDave Plumber
    oops missed that!
  2. Riley
    Stermit you say???:D
    • Funny Funny x 2
  3. mutley racers
    mutley racers Plumber GSR
    Never seen it before and couldn't believe it when found. This stuff is about 2 inches thick with dot and dab on either side. I need to move a doors location and put shower valve in this stuff but not deep enough for valve.
    Can you run a vertical waste in it from a wall hung basin or is it best to knock down and stud the walls out.
    Cheers all.
  4. Millsy 82
    Millsy 82 Plumber GSR
    Personally I would take it out and rebuild it or at least cut the one side down and rebuild. It is fairly strong stuff though but so thin you will struggle to get a 22mm through it let alone a waste pipe.
    • Agree Agree x 1
  5. Last Plumber
    Last Plumber Trusted Plumber GSR
    Stramit board, the straw stuff, I am sure is made same as an Archery Target Boss.
    The egg board stuff, I don't know what they were thinking. What's all this perform like in a fire?
  6. Mastermixlee
    Mastermixlee GSR
    Paramount partition board most likely.
    "studs" are tiny and spaced massively apart.
    The eggshell structure actually makes one side of the plasterboard support the other (hence the lack of traditional studs) .
    So if you cut too large a hole in one side it affect the strength of the opposing side.
    Crap stuff and alot thinner than normal walls.
    It's alot of work but I personally remove and replace with traditional stud wall as has more strength for mounting, and space for sound insulation.
    • Agree Agree x 1
  7. EvilDrPorkChop
    EvilDrPorkChop GSR
    Yes it's Paramount walls. We come across it quite a bit round here. Horrible stuff for getting shower valves/pipes in.
    As said above, if possible remove and replace with a proper stud.
  8. holychihuahua
    holychihuahua New Member
    I have seen them in Dunstable. They can turn a simple job into a nightmare if dropping cables or pipes down the stud wall cavity is your plan.
  9. ian.
    ian. New Member
    I had Paramount walls in my last place, the only advantage to them was getting cables down the wall got easier as I used drain rods, pushing them through the corigations down from above.
  10. mutley racers
    Thanks all. Replaced wall where door and shower valve is going.
    How is this for underfloor heating...
  11. mutley racers
    And this...
  12. Mastermixlee
    Mastermixlee GSR
    :eek::eek::eek:
    Holy feck.
    Wonder what else you'll find if you keep digging!?
    Maybe a ten gallon hat!
  13. mutley racers
    Here you go...
  14. Mastermixlee
    Mastermixlee GSR
    Wait.. What.. Did they drill it to make it a 4 way tee!!??
  15. Riley
    You have to weirdly admire the ingenuity but I can’t believe it ever worked
    • Like Like x 1
