T
torquetom1992
Ok so im having issue where our Combi 30 HE doesn't fire up all the time, the issue i have is the Fault On Fan or Flue light wil start to flash, we called someone out to fix this over a year ago, since then the problem has arrisen over the christmas period so we called our landlord who called him out again for him to simply come out take off the cover of the boiler and start banging it to make it work, then left. Withing 2 hours the boiler failed to ignite again and once again we got the light so we called him out again for him to fire up the boiler and go to our landlord and tell them the boiler is working fine.... What we have to do when it fails to ignite is run a hot water tap and leave it on until the boiler eventually fires up, we cant turn on the boiler on constant nor turn up the tempreture. Could someone please confirm this is a faulty boiler as this stupid engineer keeps saying it is fine but even i know you shouldnt have to run your taps when your boiler fails just to put heat in the radiators
