Discuss Checking burner pressures with analyser/manometer? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
As the title really folks. Who uses what to check pressures and carrying out tightness tests? I’m not to keen with the analysers to be honest. I was checking a burner pressure recently and with the analyser it was fluctuating up and down but with the u gauge it was solid?
Analyser for burner pressures and regin manometer for tightness testing.
Dont like using analyser as trying to get the right pressure can be tricky at times.
images
kane dont forget you wont be able to see the same movement on the u gauge pm is half a mbar
Got 2 testo Bluetooth manometers, link to phone, see both at same time (meter/boiler), can save/print. Also shows graph/time to check for spikes. Also got 2 testo pipe thermometers that link to same app/graph etc.
All small, fit in analyser box.
Reply to Checking burner pressures with analyser/manometer? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
