Discuss Changing old stop tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
Just wondering how you'd go about replacing this stop tap. It's not shutting off properly. It's on black poly/steel pipe, under the boards by the front door. Some words of experience would be much appreciated.
Thanks,
Jennie
Is that a tee or coupling also is before that still black poly ?
It's a coupling. I'm pretty sure it was black poly and both ends, coupled on to steel pipe. But surely the electrician wouldn't have put an earth bond onto plastic pipe???
Philmac utc to copper then female iron to go back onto the steel
You will need to turn off the utility stop outside. It may be a water meter which is easy but if its older then you will need the right key. Some say the utility dont like you doing this I have never had hassle even when I have had a gusher, well two in one week once. Rob Foster aka
centralheatking
Any identification on nuts to stopcock? Eg 22mm? If so turn off boundary stopcock, remove stopcock, fit new 22mm stopcock with ptfe on olives and tighten up, turn on boundary stopcock. Some say a little prayer to leak gods to make sure they don’t get one ;)
I guess I'll just have to get stuck in, and take it as it comes. If needs be, I can put the old one back on while I figure it out. And I regularly pray to the plumbing gods. :)
Hi all,
Thanks,
Jennie
Look Jennie the whole thing in your picture is a mess of odd ball conections. Turn it off in the road. cut out all the carp
and put it together properly.
If thats lead on the r/h side put lead lock on then copper then stop tap and then join into the domestic copper. Test ..
centralheatking
The coupling is either a VJ junior or more likely a George Fisher multi fit coupling the being used as a for runner of the LeadLoc's now available. The Stop valve is a more modern type with that style of handle. So you should be OK with new 1/2" LeadLoc to 22mm copper tube & replace the stop valve.
I wouldn't touch the old coupling the joints are made with a cone / tapered rubber with an slip ring in between the nut, a bit like a McAlpine Multi fit couple used on wastes.
I would turn off in street and just change the guts, if having removed them the seat looks ok.
Its a put new component in world in now, with the price of labour and the on cost of call backs I would replace all of it. The cost of each call to BG is ÂŁ68.00 go back twice or 3x there is no money left in the job. and they are a big outfit with economies of scale...we all should remember this and charge more and get our jobs right 1st time ish..the price of time petrol and derv and the lost opportunity cost can kill a small business. You can run around like a headless chicken turnover good money but make little profit and go bust.
centralheatking
I agree in the above sentiments Rob, however with a stop tap of solid brass - if in good nick, it is only the guts that “do” anything so why risk disturbing all the other joints trying to spring in a new body - pointless.
I’m not alone approaching this job in this way- sometimes a bit of thought goes along way.
Reply to Changing old stop tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
Hi all. Just had a neighbour knock the door regarding a water hammer issue. My own house developed this issue sometime last year as well which is when the neighbours roughly started. Severn Trent were doing bits and bobs out in the street back then but this is probably a coincidence. Our water...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern pipe/u-bend/fittings to kitchen sink, rinse sink etc as preventative maintenance! Nothing complex or specialist, that's for you expert guys! But in...
I'm a council tenant and my bathroom basin is broken and needs replacing, it has standard pillar taps. Do you know if councils would ever replace it with a mixer tap one if I paid the difference? (I'm guessing no but it's worth a try). How much more complicated and time consuming is it to...
