Discuss Changing Back boiler for Combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jbm
Hi, I will be changing my trusty old Baxi back boiler for a combi in the next couple of weeks. I am competant to do the water side of the plumb and will employ someone to deal with gas and flue side.
I am carrying out some preparations prior to proceeding and just checking before I chop a pipe or 2.
The Radiators all run from a 15mm pipe with each spurred off in turn. The returns are congregated and appear to return to the boiler via a 22mm pipe. All pipes (very handily) go in front of the chosen location for the new boiler so diverting them will be an hour or so's work including a run off for the condensate (tank overflow)
I intend flushing through the system prior to fitment of a new boiler. What are the best additives to push through the system to preserve the radiators etc?
I have up until now removed the radiators 1 at a time annually and given them a good rinse with the garden hose but I would prefer to leave them be for a few years after the new system is fitted.
Needs a power flush.
Why isn’t the gas guy involved in this choice, as he will be registering the the guarantee.
Will need doing to qualiffor that.
Soooo.....good luck if you can get someone to just run the gasline and commission the boiler.
How do you know the old system will not leak under pressure?
Needs 22mm flow and returns before teeing off for individual rads in 15mm
Powerflush is generally needed so the warranty won't be void.
Filter ftted
What you intend to do raises more questions than answers. Short term questions about system integrity and design. Long term questions about the guarantee for the new boiler, your house insurance remaining valid and its overall safety. I am sure on a
job by little job basis you can attempt this but the sum of all its parts is a worrying prospect for your home and people living there. Good luck and keep us informed of your eventual choice of course of action
So, had plumber round this morning who pointed out several errors in the original fitment of the old system. Terrible mixture of 15 + 22mm pipework (22-15-22-15 etc etc). Seems to have been patched in with 'whatever was left over from other jobs', Poor overall installation. There's a rad return taped onto a gas pipe to 'hold it in place'. Complete renewal advised.
Complete building was refurb'd about 25 years ago and going by other 'horrors' i have found in the basic fabric of the refurb. The DIY section of the heating is a no go, so whole house will be re-plumbed from scratch!
Thanks for all the replies guys.
Are you going to do the heating side?
Reply to Changing Back boiler for Combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi We have a vented oil-fired heating system with a coal fire back boiler, this is going to be changed to a sealed pressurized system tomorrow and I believe, they are decommissioning the back boiler. I have only discovered today there is no access to the water jacket, so will it be good enough...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night for a few hours using "auto"? mode I had been brought up to leave boilers on manual and set the thermostat low at night to prevent pipes from...
L
I can see the small leak in back boiler, have tried all sorts of products to seal it. have drained the radiators but pressure from water in actual and pipes boiler keeping it wet!! any ideas please to seal, its my only heating.
LyndaB
L
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered central heating installer about 15 years ago, so I felt comfortable running the flow/return to rads). I am in need of a combi boiler install with a...
