Discuss Central Heating Pipe Sizing in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. ***Tom11***
    ***Tom11*** New Member
    Whats peoples views on what pipe size i should use in the following scenario:
    2 x 3 bed houses being converted into a 4 bed.
    13Kw heating demand fed via a Worcester 42Cdi Combi, 550Cdi high flow or 35i System boiler - Customer undecided yet although i have recommended due to hot water demand required to go with the system boiler and cylinder.
    22mm from boiler and main skeleton or 28 mm and reduce to 22mm after some of the heat load has been took off to some of the rads ?
    I was thinking 22m should be fine but upon checking through various sources i keep reading conflicting advice which is making me think possibly some 28 may be needed ?
  2. ShaunCorbs
    22mm as heating demand is below 40kw
    I would go heat only / sys and unvented cylinder
    • Agree Agree x 2
  3. chris watkins
    chris watkins Plumber
    Tom, I would suggest purchasing a copy of the Domestic Heating Design Guide & reading it.
    Best £30 a heating pro like yourself will ever spend.
    • Winner Winner x 5
    • Useful Useful x 1
  4. ***Tom11***
    We both know that a 4 bed 2 bath property should have sys/unvented but she is adamant she wants a combi!
    So you think 22mm could cope with 40kw of heat load ? That seems excessive to me.
    Im not saying you are wrong at all but i wouldnt have thought 22mm would cope with that much.
    On looking at various threads there is conflicting information/answers.
  5. chris watkins
    I believe Shaun meant the 13kW from your 40kW combi.
    22mm copper will carry around 23kW at a delta T of 20degC which is what you should be designing & selecting the emitters to Tom.
    • Like Like x 1
  6. ***Tom11***
    Cheers for the info and the book tip, ill have a looksi for sure
    • Like Like x 1
  7. bogrodder
    bogrodder Plumber GSR Top Contributor!!
    13kw heat load seems rather low for 2 x 3bed houses, are these old houses with very high levels of insulation or new build houses?
    • Agree Agree x 1
  8. garygvl
    garygvl Member
    5 bed new builds on some sites are only fitting 12kw boilers.
  9. garygvl
    garygvl Member
    40k combi only runs at 40k when doing hot water. not sure what worcester ouput on this combi is on heating only without looking at tech specs but expect it to be below 30k and as your heating demand is only 13k boiler will modulate down anyway so 22mm all you need
  10. bogrodder
    Yes I understand that, but I don’t think the op’s description of knocking two houses into one, will be new builds lol...but I maybe wrong.
  11. garygvl
    garygvl Member
    you asked was it old or new build just making a comment about new builds
    edit.. by the way agree an estimate of 13k heat load for a conversion of two 3 beds into one 4 bed is low without a s..t load of insulation
  12. SimonG
    SimonG Trusted Plumber Top Contributor!!
    Sized appropriately. Or pay somebody to do it.
    • Agree Agree x 3
  13. ***Tom11***
    Apart from the recommended book from Chris above,
    What methods do people recommend to calculate heat required then ?
    One of the rooms in the property is as follows:
    Dining room
    4.6m (L)
    3.8m(w)
    2.3m(h)
    Solid floor
    heated rooms above
    no windows
    2 external walls
    Cavity walls - dont think insulated.
    Probly built in the 70's
    App gave me 1400w
    I have always used the Anton app before and has always seemed fine, no complaints. But as this is quite a large property i thought id get some advice from engineers with more experience.
  14. ShaunCorbs
    1.25kw estimated
    About an 80x60 k2
  15. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    First off, whats going in the bathrooms? Is it 2 full bathrooms with baths and showers etc or one bathroom and one ensuite? You need to answer these questions and decide whether a combi is suited, she might be demanding a combi but it's your head if it doesn't work. Also what's her mains flow rate like? If you are installing a high flow, your going to want at least 20litres a minute coming through the mains. If your converting 2 houses are you going to utilise both incoming mains? One for the hot and one for the cold supplies? As for your heating, 13kw isnt excessive so if it's sized correctly 22mm will be fine.
Loading...
Similar Threads - Central Heating Pipe Forum Date
Central Heating Circulation Problem - Single Pipe System Central Heating Forum Jan 28, 2019
Problem with central heating flow after pipe alteration Plumbing Forum Jan 22, 2019
