sinaloa
Does anyone know how I estimate how the installation of cavity wall insulation will improve the maximum temperatures I can achieve internally with all else being equal;
ie If I run my heat pump at full capacity and achieve a maximum average internal temperature of say 19 degrees before cavity insulation and then I ran at capacity again after and left the operating programme the same on a day with similar external temperatures. I presume I would expect to see an increase in maximum achievable internal temperatures but am trying to estimate by how much.
Our cavity wall insulation was delayed and resulted us getting the ASHP before the improved insulation and I am becoming increasingly sceptical about the abilty of the pump to do the job - if we can expect good improvements from the insulation we may be OK but it is all very tight.
