Discuss Bosch CDI 30 combi boiler in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
  1. Jon Green
    Jon Green New Member
    Hi, my boiler has been having an intermittent fault no one can seem to cure. When the hot tap is used , usually first time in the morning, it creates the boiler to over heat. I have to wait for it to reset itself and cool down then usually ok. Apparently not heat exchange plate.
  2. Riley
    Only advice you’ll get my friend is a gas safe engineer we will not provide any advice on diy boiler repairs
  3. Harvest Fields
    Moved to correct part of forum
  4. Jon Green
    Not asking to fix myself but to pass the info to my plumber as he has spoken to Bosch and had no luck. Thought someone on this site might be able to throw some light on the matter.
  5. ShaunCorbs
    Fixed price repair then from Worcester if he doesn’t know
    Sorry but we don’t give gas repair advice out unless your qualified
  6. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    Where are you based?
  7. Craig Watson
    Craig Watson Plumber GSR Top Contributor!!
    Try a different engineer, one engineer could scratch his head for days where another could diagnose in an hour.
  8. Jon Green
    Thanks. I have so far spoken to my heating engineer who services my boilers and he said no point in coming out until it completely stops working. Also a plumber who was recommended and I have to say is very good. He came out and said very difficult with an intermittent fault but after phoning Bosch tried their advice but to no avail. I have spoken to other engineers who all are not sure what it could be. Meanwhile I have a boiler the every time we go to have a shower in the morning bangs and shows U9 then slowly drops in temperature until it starts up again. Then it tends to work OK. Not great when it services our house and attached holiday let. Just want it fixed
  9. Harvest Fields
    If you’re not happy. Then the only option is as above. Fixed price repair from Worcester themselves.
    • Agree Agree x 1
    • Winner Winner x 1
Loading...
Similar Threads - Bosch combi boiler Forum Date
What is this error code on Bosch combi boiler? Central Heating Forum Apr 15, 2019
Worcester Bosch flue self tapers? Central Heating Forum Thursday at 5:35 PM
