- Messages
- 359
What do you do? One after the other, it seems I've had a run of boilers loosing pressure, some with obvious causes, others with 'no' cause, and most with customers that want a cheap quick fix.
Hourly rate / or fixed price? drain down boiler, check expansion, check prv obvious leaks...and.....?
Then if expv replace or pump up? If you pump and then get a call back... how do you play it?
Prv will need to be ordered/ bought and a return visit- and at what cost?
PRV on Worcester is a ripper-hands in shreds trying to do them, have done a few but now reluctant.
Loved just topping the pressure up when I first started but I had one where the bloody rad started leaking afterwards and the customer had a hissy fit.
