Discuss Boiler Heat Exchanger busted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Well you can clearly see the heat ex has rippled so either the system is badly sludged up or your system pump is running slow/seized and the system was getting warm from gravity circulation. I wonder, did the installer actually wire the pump into the boiler to handle the overrun and that’s whats goosed the hex
Out of interest, have you got his warning notice. Love to read what it says
That equipitential bonding is illegal for a start its after a tee
Wrong
Soldered tee is fine
Compression is ncs
Nothing wrong as it’s a sparkys remit
Reply to Boiler Heat Exchanger busted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
We just had a service done on our Ideal ICOS boiler and were told that the 2 screws on the back of the heat exchanger have snapped off. It was marked as dangerous and has quoted a whole new heat exchanger as there are still bits of screws stuck inside that cannot be removed. For 2 broken screws...
Hi, Boiler is losing pressure, from 1.5 bar to 0 bar in about 4 hours. Have checked all rads and seem to be fine, no water out external prv pipe. If the heat exchanger is faulty what do I need to look for? There is a constant run of water from the condensate pipe when heating on but not sure...
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate tank. There is a thermostat on this second tank that pushes hot water over to the store tank when it's hot. It's a closed loop and goes through a heat...
Hi All, Have a peculiar problem with my Gloworm Flexicom 30cx combi boiler, the main heat exchanger is getting red hot and fault coding on overheat even though the boiler and central heating is not on, i shut the boiler down for a while, clear the fault code and it will be fine again for...
1K
I have a Baxi Duo Tech 28 HE. According to an online search with the serial number and GC number, I should have a 20-plate heat exchanger. So, I purchased a 20-plate unit. However, when I removed the old part, it appears to have 12-14 plates. Is there any harm in installing a 20-plate exchanger...
