Discuss Blocked kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The kitchen sink in my second floor flat has always been problematic.
It's finally given up the ghost.
The setup is the main sink, rinsing sink and dishwasher. I'm guessing the grey flexipipe is the actual waste pipe? I can't see as it disappears down the back.
  • I've tried plunging both sinks (this usually helps with minor blocks). But this time it doesn't really do much - it just pushes water to the other sink.
  • I've tried a couple of products to unblock the sink with no luck.
  • I've taken off the grey flexipipe in the picture and tried a 6ft rod down it, with no luck.
  • When I take off the flexi pipe, water drains fine from the sink out of the white pipe.
  • When I put water down the flexi pipe alone, it holds water. Is this the problem pipe?
  • I've had the dishwasher running to see what happens & the backs up into the sinks.
Does anyone have any further DIY recommendations to avoid a call out (money is tight atm).
https://i.*********/F3KpSO7.jpg
Can you get another photo from further round to the right? it just helps a bit to get a better perspective on what's connected to what.
Where's the washing machine out of interest. You mention dishwasher but the two flex pipes would suggest to me two appliances connected... the waste would/should ultimately drain out the white pipe in the rear left corner.
It doesn't seem right that the flexes go downwards at the back... they should be above the sink trap other than where they connect to it.
Forgot to add, its a bit hard to say from that pic but it looks like the fall might be off and the way the have connected the two sinks together on the solvent welded pipe looks less than ideal but that might be more to do with the phot. If you could take another photo of the solvent welded pipework on the lefthand side, trying to capture more clearly where the pipe from the right hand sink joins the pipe from the left hand sink, it might be helpful.
Thanks for the replies. Not sure if the below helps (took them before I left). Can try and get in there and get some more pics when I get home.
The washing machine is in a cupboard in the hall with the boiler.
The only thing connected in the kitchen is the dishwasher.
https://i.*********/qmULVrD.jpg
https://i.*********/Ntr0T6J.jpg
Okay those pics do help... The grey Flexi pipe at the back is nothing to do with the waste system, so ignore that.
The grey Flexi pipe on the front is the waste pipe from the dishwasher... That won't be causing your issue.
You're issue lies somewhere in the white pipework... If both sinks back up/ don't drain then the blockage will almost certainly be somewhere in the pipework behind the unit or further down the line... Which is obviously a bit more of a pain if you're not able to remove/replace pipework yourself.
The best thing I could suggest before calling someone out would be to remove the trap underneath the main sink (the connection shown in your last photo) and do what you can to rod down the now exposed pipe... Or if rodding doesn't help, a load of bleach left overnight?
Okay, thanks. So I've been working on the wrong pipe for ages :rolleyes::rolleyes:
So the white pipe that goes into the grey pipe, which then runs behind the boards is the one I need to be working on. I'll try the rod and sink unblocker down there too. It's whether I can actually get the rod down there - there's a lot of curves and all the stuff at the back is solvent welded.
Indeed... if both sinks are blocked then the blockage will be further down the system (i.e. after where the two sinks wastes join together in the back left corner and go down below the units).
You'll never manage to rod through the trap hence why I suggest removing the trap from the main sink (have a bowl/towel ready!) As that looks like the easiest path to get the rod down (albeit not ideal)
Both do back up. So it seems the problem has been pinpointed.
Yeah, I've had the trap off already. Bowl is ready and primed.
Thanks for the advice. I'll get to work on that once I get back from work today. Hopefully the 6ft rod is long enough and can do the job.
Is bleach enough to dump down there? Or are there any good products I can get over the counter?
Chemicals are rarely the answer in my experience, though I'm currently renovating a bungalow (living on site) and the shower waste is concreted in and slowly blocks over several weeks - I've found thick bleach is just as good as any expensive/branded drain unblocking product! Leaving it overnight seems to work a lot better than a quick few hours before rinsing too.
Physically unblocking it is going to be a much better solution, the question is just how far down the blockage occurs.
Best of luck!
Chemical weapons generally just make it difficult and dangerous to subsequently use mechanical unblocking as they fill the pipe with caustic material which splashes about when you're rodding. Also they can cause heat which can soften the pipe and make it sag. Imo avoid. Take off the trap on the left and rodding down the grey 90 knuckle bend it looks like the trap on the right joins the left and goes out through the back wall behind the left side. Wear goggles if you've put chemicals down it recently. Then go out into the garden and look in the gulleys and manholes to make sure they are running well. Also ask the neighbours downstairs if they have any drainage issues. Let us know how you get on.
Sorry, im not sure exactly what you're using. For diy you might look at something like this:
https://www.NoLinkingToThis/p/drain-unblocker-25ft-7-6m/11325
It's not the real deal- they run into the hundreds of pounds.
There's plenty of youtubes showing you what to do.
I was using one of those metal 6 foot metal type things from B&Q.
I'll pop into ScrewFix on the way home and try and get one of those 25ft ones. Last attempt before a call out I think.
Thanks again.
I've bought the 25ft snake. I can't thread it all the way down.
I'm not sure where the actual waste outlet is. The shelving under the sink seems to be fixed together permanently.
Could it be behind the dishwasher?
I managed to get the boarding under the cupboards off to take a look.
  • The sink is in the right hand corner as you look at the work surface.
  • There is a pipe that runs from behind the sink all the way to the left hand corner of the room behind the cupboards.
  • It looks like there is another grey pipe that connects to this.
  • I can't see where they go (I presume into a main waste oulet)
Push it down the pipe until you feel resistance (hopefully the blockage). Lock it off with about 4inch of snake out of the pipe, push gently forward while rotating the handle. Repeat. Don't kink the snake - gentle pressure and rotating, let the tool do the work.
Good to hear you sorted it! I might be missing someone else saying the same thing, but never tip drain cleaner down a blocked drain or sink.
Reply to Blocked kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
