Discuss Blocked cylinder circuit? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ve not come across one of these before and I’m after a heads up on what lies beneath if anyone can help.
This is the flow and return pipework and is connected into what would otherwise be a blanking cap or immersion element.
There’s a few possibilities of course but I’m wondering if it’s just two pipes of different lengths, flow at the bottom, return at the top of a direct cylinder and plumbed into a y plan.
The cylinder circulation is pretty much non existent but central heating is fine. I’ve tried googling all sorts but I’m getting nowhere finding a replacement.
Thanks.
Just check as this is a really cute way of getting solar thermal heat into a cylinder..
otherwise put a diagram up..so are the primary connections on the side there ? all hooked up to the boiler ? and h & c feeds top and bottom...it could be a crude primary cylinder heater cause the coil went years ago...
tell customer its a bit off the wall and you cannot give a fixed price until you are paid to explore..then change the lot and charge loads
its quite off the wall so you would not see it often, fun tho
centralheatking
Thanks centralheatking, there’s definitely no solar on this rented property. Those two pipes are the flow and return from the boiler, there’s no 22mm coil like you’d normally expect on a cylinder on a boiler system. I’m guessing it’s a cylinder designed for an immersion element only but has this handy gadget to allow conversion to a heat only boiler.
It'll either be a loop of 15mm pipe a similar length to an immersion heater, in which case it won't have anywhere near the surface area of a more conventional 22mm coil.
Or it will be a small bore heat exchanger internally connected to the 15 flow and return and will probably be scaled up.
Or maybe a piece of 40mm tube sealed both ends with 1 x 15mm tube passing internally the the bottom with open end and the other 15mm tube into the top of the 40mm and open ended.
Whichever it is, it's also only fed with 15mm flow and return so cylinder recovery would be slow even if the unit was working at full efficiency.
Is it free of air in the 2 short stubbs?
This appears to be 8mm or 10mm entry,
Solar Panel Hot Water Immersion Coil Heat Exchanger Retrofit Coil | eBay
Or (following on from @snowhead), they could be 'blades' which was another similar idea but they were four or five flat tubes like swords to look at but they did the same job. I see one side is equipped with a manual vent, is the other side vented into the system somehow? If not it could be air locked.
The tube type had fins around them to increase the surface area over that of 15mm tube.
They were never that impressive but they did work.
Thanks for all the help. I’ve dosed the system with Sentinel X800 and I’ll be back tomorrow to flush it all. I’ll see exactly what that thing is tomorrow and post it here.
It wasn’t air locked. I don’t like that old style of bleed valve so I just loosened the top it the compression T’s and it was dripping instantly... no notable hiss of air.
well done so far tricky thing to walk into but as its your job & only you can sort it but thats the buzz of being a self employed fella on your own
I still love it centralheatking
The Blade type were narrow and if the system is dirty, it didn't take much to slow them down to useless. I suppose all types were a bit naff really. It would take a long time to heat a cylinder of water, even when they were new.
This is the 15mm type, some had fins as I mentioned earlier.
Pigs tail ch immersion heater for direct cylinders
It looks to me to be a Hot Tube, which is just a coil that means you can convert an indirect cylinder into a twin coil, using that Hot Tube for oil or gas heating.
Very prone to blockage and only heat part of the cylinder and slow recovery.
I would likely give best advise and just recommend upgrading it all.
Like stated it will never be very efficient. Just explain to the customer there are a lot better methods than this and it will never be very good.
Hot tubes used to be made by makers of Spartan tanks, all disappeared when sealed systems came in
Thanks to all the replies. I bought the ebay item that was suggested and wasn’t entirely happy with it once I saw the limitations of it. I disconnected the existing one and jetted it at an external tap and refitted it and it’s working ok.
The ebay one was a 10mm copper coil, homemade but satisfactory and I’d have installed it had the 15mm existing one been unsalvagable.
In the end, I’ve flushed the system and explained to the customer that it’s an obscure device that serves a purpose but is never the first choice for how water supply. I’ve recommended changing to a Combi when the boiler is due an upgrade.
The property has an electric shower so the cylinder is only really used for a bit of washing up so it should be acceptable for now.
Hello they were used alot on micro bore many years ago if not the same as you have or something simliar many a plumbers hearth were broke only thing i would do there is buy a coil and fit it in the cylinder just be carefull what coil you buy threads are fine on some of the coils so when you tighten it up it will strip the threads thats a given or replace cylinder good luck
Had a similar arrangement on our current property when we moved here 4 years ago. Normal primary coil was plumbed into an oil Rayburn, and immersion hole coil like yours was connected to primary from pressurised oil burner boiler via 3 port MV.
Have since got rid of Rayburn and primary from boiler goes to standard coil in a new cylinder. Unless your cusomer wants 2 different primary water heat sources to direct to cylinder then recommend a new insulated cylinder and connect up to the more efficient central coil. They can then also have electric immersion as back up. For multiple wet heat sources to cylinder its either dual coil cylinder or use a Dunsley neutraliser, but either option will take up more space than current cylinder.
Reply to Blocked cylinder circuit? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
