Discuss Best unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DGT plumbing
Opinions please unvented fitters, what do you think is the best unvented cylinder on the market. I am G3 registered before you ask.
Gledhill my go too
I used to like the centerbrand / plumbs cylinders but they seem to have got too expensive.
Ultrasteel cylinders are Tribunes with grey lids , they take some beating.
Hate megaflo with a passion. Which is funny because I went on to fit many a centre brand one, made by heatrae.
Swapped onto Warmflow, but only did a couple. Didn't come with compression connectors so you needed a fitting for every connection,
Now using RM, quite happy with them.
i like Oso cylinders as the smaller ones the pressure vessels are hidden by the lid you can remove them without any pipe cutting if there is a problem as all pipes can come up behind, also the drain off is at the bottom of the cylinder so nothing left in the cylinder.
i was told by someone who worked at gledhill that they were, the person worked at a pretty well known plumbing supplier before and went back after she worked at gledhill, so no reason not to believe them
Reply to Best unvented cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
