Discuss Bedfordshire site plumbing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi is there any plumbers working on sites in the Bedfordshire area??
I can’t talk for Bedfordshire but in Hampshire it’s ok. Prices have been the same for about 20 years though which is unbelievable really
Second fix
140 combi
50 gas carcass around 2 metres give or take including hob
20 Kitchen carcass, condense, cold main etc
70 bathroom
40 en-suite/ cloakroom
10 rads
30 Zone valves and auto bypass
30 protection for sanitary ware
I appreciate what your saying mate. I worked for myself for 12 years in the domestic side but newbuildis a different animal mate. Remember it’s all dry plumbing also. It gets filled at a later date.
My apprentice does 9 rads and cloakroom,
I do the rest.
Please don’t try to insult me by saying I’m rough or whatever. I’m not it’s just quick and simple work. I’d rather not do it but needs must. It is what it is
The rads on newbuild using 10mm plastic are easy. Normally stud walls with noggins in. So a rad takes about 15mins. No way could I do a full house second fix in a day though
Naa no noggins in new build most of it is metal stud
Most new are plasterboard fixings or expanders
These are timber frame, osb pattress behind rads. Bathroom/kitchen/cloakroom is plylined behind plasterboard. No wall plugs needed only for downstairs pan.
Not knocking anyone on here but my mate has just bought a new house and the plumbing is absolute rubbish. Had endless issues with various bits, rads not level, system not tested, flue not right, Grohe toilet frames fitted wrong , leaks on rads (Airvents not tightened, tails leaking). No doubt there will be more.
Personally I wouldn't do site work, I always stick to domestic. Don't have all your eggs in one basket, least with Domestic you have a larger customer base (Or that's the theory!)
I work on a lot of new builds/conversions. I would never buy one of these places. The quality of workmanship isn’t great. Although I like to think my plumbing is the best part
Yeah, normally metal stud. Still fit noggins between them though or osb. So hanging a rad is just 4 screws
That’s if you install it
Builders won’t
I'm with Jimmy18 here. We always have noggings fitted for everything by the chippies where we work. I can also do a combi, kitchen Carcass, cloakroom, bathroom, and 10 rads on my own in a day.
The main sites round my area don’t do have to sort them out your self even supply the ply for the boiler to go onto
I’m trying to get into this plumbing game the domestic side of things, would working on site as a plumbers mate be benificial as I have been offered a job working on a new hospital site?
Not sure but it’s delivering water to appliances and fittings through pipework in a safe manner whilst discharging waste and grey water safely through more pipe work into a sewage system I’m guessing.
I got experience doing all this in a warehouse in a training establishment and in my own home but can’t seem to get any experience domestically so going from a plant fitters role to any sort of plumbing role would be a step in the right direction.
I guesse what I am asking is would I get much experience as a plumbers mate or will I be cutting threads and bending low carbon steel all day long?
You will have to start doing those jobs until you can prove you are capable of other tasks
But yes it’s a step in the right direction
Reply to Bedfordshire site plumbing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
