Poxi
E168 PCB Failure...99.9% of the time :wink5:
Discuss Baxi due tex 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E168 is internal bus time out pcb internal conflict
Remove the Gas Valve plug and check:between pins 1 and E is open circuit. between pins 3 and E is open circuit.(open circuit will be shown as 1 on the resistance setting of the multimeter)If not replace the Gas Valve●
Remove the Igniter black mains plug and check:between pin L and the boiler chassis is open circuit.between pin N and the boiler chassis is open circuit.(open circuit will be shown as 1 on the resistance setting of the multimeter)If not replace the Igniter●
Remove the Pump wiring cover and the wires from the terminals and check:between terminal L and terminal E is open circuit between terminal N and terminal E is open circuit (open circuit will be shown as 1 on the resistance setting of the multimeter)
how common are they poxi? i have a massive amount of plats/golds/heatmaxs in some are 6 year old never had a single pcb goE168 PCB Failure...99.9% of the time :wink5:
Reply to Baxi due tex 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
