Discuss Bath waste drain in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Roy
    Roy New Member
    Hi all
    Looking for possible advice.
    I recently bought a 12/13 year old 3 story semi detached.
    In the living room below where the bath is in the bathroom there was a patch where it looked like there had been a leak.
    Firstly the sealant around the bath isn't very good and there are signs underneath of water getting through.
    So that will be one job easily sorted.
    Looking under the bath at the waste end it looks like the trap/waste has been replaced.
    I'm not a plumber and I may be wrong but should it go down and then up and over?
    The water does take a while to go down but have not used the bath properly with hot water as we have a ensuite.
    Thanks in advance for any advice.
    Roy
  2. JCplumb
    JCplumb Plumber
    That does go down and then up, it's fitted properly.
    • Like Like x 1
    • Agree Agree x 1
  3. Roy
    Roy New Member
    Ok thanks JCplumb
    Just wanted to make sure before it gets used regularly.
    Maybe just check the trap is clean and hopefully that's it.
  4. Best
    Best Trusted Plumber Top Contributor!!
    Also check if there is any downwards movement on the top edge of bath by pushing down around the top with your hands. If there is movement, then silicone joint might pull away from bath or tiles easily and cause a leak.
    Ideally the plastic baths should have the top edge supported or even just glued to wall to prevent movement
    • Agree Agree x 2
  5. Roy
    Roy New Member
    Thanks Best
    The sealant does need doing it has a plastic bead around the bath with sealant holding it in .
    We a tiny bit holding it and a gap in the corner.
    But I will do that no problem.
    • Like Like x 1
  6. Harvest Fields
    Support is best in my opinion.
    • Agree Agree x 1
  7. Best
    Yes, a timber baton screwed to wall is my preferred method. Surprised though how good a job sometimes just glueing bath to wall using silcone can be.
    • Funny Funny x 1
  8. Harvest Fields
    Always much harder to remove and takes the wall with it:p:D:D
    • Funny Funny x 1
  9. Best
    I may have mentioned this before, but I installed a bath which was replacing an old bath, but perfect wall tiles remaining. I used silcone (not my usual install method) which allowed me to temporarily wedge the gap to tiles to maintain approx a 3mm joint when silicone set hard.
    Struggled to remove that same bath years later after tenant dropped something on it. Cut it in bits and the short parts of rear edge just stayed solid.
    Really surprising the grip silicone has if the wall finish is suitable
    • Funny Funny x 1
Loading...
Similar Threads - Bath waste drain Forum Date
Bath waste leaking when bath drains Plumbing Forum Jan 3, 2019
Cross joist waste for bathroom sink Bathrooms, Showers and Wetrooms Jan 31, 2019
