Discuss Basin mixer tap with pushfit flexi tails in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. John Massey
    John Massey New Member
    Hi
    I need to buy about 20 mono basin mixer taps to connect to 15mm plastic pipes. I can't find any that come with pushfit tails which means either throwing away all the tails to buy pushfit tails or buying adaptors which seem to be as expensive as new tails.
    Do you know of any cheap contract taps that come with pushfit tails or cheap adaptors please?
  2. ShaunCorbs
    Nope
    Why do you need push fit ends just use a compression insert
  3. John Massey
    What do you mean by compression insert? I've used olives on plastic pipe before and after time they leak due to plastic deformation.
  4. Ben-gee
    Ben-gee Plumber
    Well you aren’t doing it properly then!
    • Like Like x 1
  5. Harvest Fields
    To use compression on plastic the plastic needs to have an insert.
  6. John Massey
    Well actually it was done by the builder. But any tips for a proper job please?
    Is a compression insert the alloy or plastic sleeve that goes inside the pipe?
  7. Ben-gee
    Ben-gee Plumber
    To be honest plastic needs an insert whatever the fitting.
    • Agree Agree x 2
    • Like Like x 1
  8. Harvest Fields
    Depends what pipe it is.
  9. Ben-gee
    Ben-gee Plumber
    No offence, if you’re being paid to fit 20 taps you ought to know what you’re doing. If you’re not fitting them, leave this aspect up to the plumber and don’t worry about it
    • Agree Agree x 2
    • Like Like x 1
  10. ShaunCorbs
    What manufacturer of pipe is it ?
  11. John Massey
    It's Hep2O but I've used Speedfit connectors a lot and they seem fine. Speedfit manufacture a coupling (male 1/2 BSP-15mm) but very few people seem to stock it.
  12. ShaunCorbs
    Buy the hep insert the metal one then you can use a comp fitting
    Or use the hep insert with the speedfit 15-1/2 and find taps with 1/2 flexis
  13. Best
    Best Trusted Plumber
    And make sure to use copper olives on plastic pipes, not brass.
  14. John Massey
    Thanks. I thought all olives were brass. I live and learn.
  15. Best
    You get brass or copper olives and brass compression fittings and valves can come with either type.
    Brass is good on metal pipes, but copper olives must be used on plastic pipe because being softer it seal well or you risk the joint weeping
Loading...
Similar Threads - Basin mixer pushfit Forum Date
Toilet and basin connection issue? Bathrooms, Showers and Wetrooms Apr 24, 2019
Mixer tap, bath heats fine, shower fluctuates. Bathrooms, Showers and Wetrooms Monday at 9:47 PM
