Discuss Balcony flue kit across a passgeway in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon,
Is it possible to run a flue balcony kit across a public passageway. And if so what would the minimum height be.
Have a gloworm ultracom 30xi that was on a twin flue (no longer) available.
Martin
Need pics on the public passage way
Why not keep the twin flue eg install a new twin flue
Baxi
Viessmann
And one I can’t remember atm
These all do twin flue systems
Is this to be fixed under a balcony or run across free air?
When you say Public, is that part of access to flat complex or just a general walkway?
Sketch or photo may be handy.
Baxi
Viessmann
Baxi don’t do it anymore, doesn’t meet the efficiency targets our rep said, Keston are the only ones now, which is basically an ideal logic+
They do converts a single to twin
That’s plume displacement not twin flue
Look before you comment pg8
But I’ve just asked waiting for a response
Ah apologies, not all the pdf loaded on my tablet first time, I see it all now, all the different variants of flue types, the bottom of each page is dated 2011 I see.
Please post when you get your response
still available
That only goes upto the 33kw. They don’t do it for the light commercial setup.
Who said about commercial or over 33kw op existing boiler is 30kw ???
As for if you want to go over 33kw more than one boiler into a llh sorted
No idea mate as I do not fit Baxi. Hence I called the commecial rep and he said that they don’t do anything with a twin flue.
Yea commercially they don’t
Reply to Balcony flue kit across a passgeway in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a open flue old boiler (natural draft for combustion) installed on outside wall. Before winters want to install a heat only condensing boiler (room sealed), cannot install it at the current location as it is open to weather effects (rain and sun light in summers). I cannot install it in...
Hi all Hope you can help We have a Gloworm Ultracom 38CXI combi boiler. During the Summer the taps and mixer shower run hot water consistently hot for as long as need be, but now during the Winter when the radiators are on the taps and mixer shower will run hot for only a few minutes and...
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current boiler is on an external kitchen wall with the flue going straight out. However, it's positioned in between a door and the kitchen window, quite close...
A
Hi there, I recently purchased a flat that was built in 2016. The apartment is still under the NHBC 10yr warranty. Since moving in, I discovered that the rainwater pipe that runs through my winter garden balcony at one end of the property is connected to a combined water/sewage system with the...
Amelia
A
Hi guys. How many of you use a roofer to help with vertical flue installations, or do you rather do it yourself?? I’m not one for heights so would rather not if possible.
