Discuss Balcony flue kit across a passgeway in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon,
Is it possible to run a flue balcony kit across a public passageway. And if so what would the minimum height be.
Have a gloworm ultracom 30xi that was on a twin flue (no longer) available.
Martin
Need pics on the public passage way
Why not keep the twin flue eg install a new twin flue
Baxi
Viessmann
And one I can’t remember atm
These all do twin flue systems
Is this to be fixed under a balcony or run across free air?
When you say Public, is that part of access to flat complex or just a general walkway?
Sketch or photo may be handy.
Baxi
Viessmann
Baxi don’t do it anymore, doesn’t meet the efficiency targets our rep said, Keston are the only ones now, which is basically an ideal logic+
They do converts a single to twin
That’s plume displacement not twin flue
Look before you comment pg8
But I’ve just asked waiting for a response
Ah apologies, not all the pdf loaded on my tablet first time, I see it all now, all the different variants of flue types, the bottom of each page is dated 2011 I see.
Please post when you get your response
still available
That only goes upto the 33kw. They don’t do it for the light commercial setup.
Who said about commercial or over 33kw op existing boiler is 30kw ???
As for if you want to go over 33kw more than one boiler into a llh sorted
No idea mate as I do not fit Baxi. Hence I called the commecial rep and he said that they don’t do anything with a twin flue.
Yea commercially they don’t
Reply to Balcony flue kit across a passgeway in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
