Discuss Atag XL110 Flueing issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nico
This may be a bit of a daft question but seem to be having issues with 4 Atag xl110 when running on low fire and believe there could be an issue with the flue but when check-in Mis I noticed it says flue gas outlets under pressured and flue gas outlets over pressured. What is the difference in these configurations? Cheers
are you commercial ?
whats the issue on low fire?
The O2 percentage is meant to be between 5-7% there is 4 boilers back to back going onto a common flue header but when running on low fire the percentage was 12% when trying to adjust the offset on gas valve when I was getting to roughly 10% the CO ppm was flying through the roof. These are newly installed boilers but have used existing class 1 flue
What was the high fire stats
Have you tried firing one boiler at a time on low ?
How long are the flue and is there a secondary flue fan fitted ?
Is could I would find out the max flue run on the Atags should be in the manual and then go from there
If you can’t find it phone tech up there a good bunch but commercial only so need to know what your talking about
Reply to Atag XL110 Flueing issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
