Discuss Are undertile bath seals any good really... in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. James Firth
    James Firth New Member
    Hi all,
    In the next few weeks I am looking at getting my bathroom redone and have purchased a Carron sigma 1900x900mm bath.
    My question is are these undertile bathrooms seals any good?
    Some I've been looking at are 50 quid for a kit. And some 8.99 for a 2m strip.
    The over tiles seem to be useless and a lot of people saying they just done stay on.
    I've been looking at the undertile ones as I thought they would be better at keeping water out and for staying on.
    Am I better just getting it silicone sealed around the edge? I was just worried a finish like that would let the bathroom down...
    Any help would be great.
    Cheers Jim
  2. SimonG
    SimonG Trusted Plumber
    Do not use them crappy under tile sealing strips.
  3. James Firth
    Advice taken mate. Just wonderedwhy there hates so much. They seem like a good idea. Is their an alternative or just good old silicone?
  4. king of pipes
    Never use em good old silicone has always worked for me . Kop
    • Like Like x 1
    • Agree Agree x 1
  5. Ben-gee
    Ben-gee Plumber Top Contributor!!
    Better off spending the £50 on a Cramer fugi silicone profiling kit and a few cheap tubes of silicone and get practicing!
    A skilfully applied bead of silicone not only keeps things water tight, it is truly a thing a beauty.
    • Like Like x 1
  6. apcdave
    apcdave Member
    classical when bath installed - then bead of silicone - never fails
    • Like Like x 1
  7. YorkshireDave
    YorkshireDave Plumber Top Contributor!!
    Personally, I've used the blue 'classic' ones a good few times now. Especially on rubbish walls such as the folded ali foil studwork!!
    I did it because movement was always a problem and the strip accommodated quite a bit with out leaking. I found it required a bit of forthought in that the corner had to be 'puckered up' rather than simply wrapped round the bath to get into the corner properly. They certainly stick like the proverbial to a blanket!!
    As I've never had a call back, I've assumed that worked! Or it could be that I've changed my number . :rolleyes::D
  8. Millsy 82
    Millsy 82 Plumber GSR Top Contributor!!
    If you have plasterboard walls remove all plasterboard in wet areas (all round bath behind basin etc) replace for the green plasterboard or aqua board. Put the bath in silicone it with good quality (I use dow corning). Then tile then silicone it again.
    If the silicone starts looking tatty in a couple of years then scrape all the existing out and re silicone.
    This is what I was taught years ago and it seems to of worked well for me. A lot of the bathrooms I go to that need everything removing is because they have used cheap nasty silicone and applied it over the existing then it doesn't stick soaks under then soaks all the plasterboard and then all the tiles fall off and the customer moans that I can't fix it with out stripping the whole bathroom out and starting again.
    Do it right this time save yourself a lot of work in the future.
    • Like Like x 1
  9. James Firth
    Cheers for all the help guys. Think I'm gonna go down the green plasterboard and just silicone around the bath route. Trying to keep costs down.
  10. Millsy 82
    Some things you dont try and keep your costs down you do it for what it costs. What you dont want to do is spend 3-4k on a bathroom that should cost 6-7k then have to spend another 3-4k in a couple of years.
    A good bathroom will put thousands on your house a badly installed one will take just as much off.
    • Agree Agree x 2
Loading...
Similar Threads - undertile bath seals Forum Date
Roman bath nightmare, cannot fix the leak Plumbing Forum Yesterday at 4:23 PM
Vintage Bath and Basin tap help Valves & Taps Saturday at 1:50 PM
