Discuss Are there TWO types of brackets for square guttering? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
No problem fitting a standard bracket over the guttering, but when I get to the hopper, the barcket will not fit over both the gutter and hopper. Is there another size or type of bracket for connecting gutter & hopper together?
A photo would say a million words here? Hopper normally has screw holes in back of it and the joint is built in
OK, only one type of bracket. Where am I going wrong- I cannot clip the bracket over the gutter and hopper. There simply does not seem to be enough room in part of the bracket that is allocated for this.
As previously pointed out
There is holes in the hopper to fix it to the facia boards no need for a bracket
Yes, I understand what is being said there, but how am I going to clip my gutter to the hopper?
Do you mean Hopper;
[DLMURL="http://www.drainageonline.co.uk/Floplast-68mm-Round-Plastic-Downpipe/68mm-Round-Downpipe-Rainwater-Hopper.-RHS1.htm?gclid=CJ_7hf7zzbkCFbIPtAod4wMAFw"]68mm Round Downpipe Rainwater Hopper. RHS1 | Floplast 68mm Round Plastic Downpipe | Drainage Online[/DLMURL]
Or running or end outlet;
112mm Half Round Running Outlet. RO1 | Floplast 112mm Half Round Plastic Guttering | Drainage Online
Running outlets have built in clips to hold the gutter in place.
Hoppers collect more than 1 downpipe or outlet.
It is as you say a running outlet. I`ve worked out where I was going wrong though. I had slid the gutter too far in, (past the hole). That bit of plastic protruding at the side of the hole was under the gutter preventing the gutter seating correctly (nearly broke my fingers trying to press the clip in to place):blush5:
If you had not asked me to get a photo I may not have noticed that. Thanks for ALL the replies.:grouphug: Hopper.jpg
Remember to cut it to the correct length so you don't get the noise in the summer sun.
Reply to Are there TWO types of brackets for square guttering? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
