Currently reading:
Any gotcha's to drain and refill a hotwater tank to replace 2 x immersion heaters?
Discuss Any gotcha's to drain and refill a hotwater tank to replace 2 x immersion heaters? in the General DIY Plumbing Forum area at PlumbersForums.net
My daughter has all electric heating, however, the lower economy 7 immersion has failed (high resistance short to earth).
I received what I consider a ridiculously high quote of over £400 to drain the tank and replace both immersions (upper boost immersion is working but 8 years old so I assume worthwhile replacing at the same time).
I'm a practical diy'er and ex electrician so considering doing it myself. It looks straightforward from the pics to: ensure all electrics are off, shut the cold water feed, open a hot water tap to drain pipes then drain the tank with a hose, but before I do is there any advice you prof's would give? e.g. loosening the immersions before draining, or does anything need to be done at the expansion tank before or after?
Does that price include to service the unvented?
Does seem a bit on the high side best to get another quote / estimate
Depends how tight they are if you feel upto to it it’s down to you
Would replace them with titanium immersion and replace the drain washer aswell
Technically no as it doesn’t interfere with any safety components
Unvented immersion Sod easy to undo compared to the older ones usually cos rely on rubber seal. Make sure you buy the correct type of immersions, the standard ones from screwfix are not the same thread size.
It's the replies regarding G3 cert that have really helped here. They prompted me to read and become more aware of the safety aspects of unvented cylinders, so I will focus on getting more quotes, include a service as I suspect one has not been done for at least 4 years and specifying titanium immersions.
Thanks all.
Reply to Any gotcha's to drain and refill a hotwater tank to replace 2 x immersion heaters? in the General DIY Plumbing Forum area at PlumbersForums.net
