Discuss Any advice on installing basin and tap? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. falable
    falable New Member
  2. AMGasServices
    AMGasServices GSR
    • Like Like x 2
    • Useful Useful x 1
  3. falable
    falable New Member
    hi, i forgot to mention its a smaller bathroom, just shower/toilet/basin.
    also i dont remember where my wall studs are, so will the basin be held onto the wall by just the fixing?
  4. AMGasServices
    AMGasServices GSR
    You could try and see what happens. I’ve used them a few times and they have been on solid walls. Baring in mind you’ll also have the pedestal that will also take some of the weight.
    Replace all the waste traps and pan connectors with a decent branded types such as MacAlpine. You don’t want to take the stuff apart once its finished.
    • Like Like x 1
    • Useful Useful x 1
  5. Rob Foster
    Rob Foster Top Contributor!!
    Do not use plumbing fittings water or waste from bq etc they are poor quality and do not fit each other well...go to,your local plumbers merchants. Get
    plenty of ballo fix valves and bang them in so when you get a water leak you dont have to panic. Use multikwick pan connectors and mc alpine waste. keep us informed of progress ...good look. centralheatking
    • Useful Useful x 1
  6. Ben-gee
    Ben-gee Plumber Top Contributor!!
    For that type of basin/pedestal you are fine fitting to studwall. The pedestal takes the weight and you just have two screws to stop it coming away from wall. Use brass or stainless steel screws. You don’t need the basin fixing bolts for this situation, and probably that basin could not use them anyway.
    • Agree Agree x 1
    • Useful Useful x 1
  7. Rob Foster
    Some people have been known to use car body filler to stick basins back to the wall I find it quite effective but you only get one chance. Rob Foster aka centralheatking
  8. Ben-gee
    That sounds daft, a couple of small blobs of silicone if you must.
    Remember these things should all be reversible, if basin gets cracked you shouldn’t have to destroy bathroom to remove it!
    • Like Like x 1
    • Agree Agree x 1
    • Winner Winner x 1
  9. WC1
    WC1 Active Member
    If you don't want to buy them by the box you can get small quantities of stainless steel screws on eBay. Brass is ok but a bit soft. I don't use anything other than s/s in bathrooms and usually throw away screws supplied. I think it's a worthwhile cost.
    • Like Like x 1
  10. YorkshireDave
    YorkshireDave Plumber Top Contributor!!
    Sorry to be a pedant WC1, but stainless is LESS robust than brass. Stainless is annealed (softened) as part of its corrosion resistance process.
    Most brass screws in this instance use a traditional slotted head. Stick with those as the shank under the head is thicker so stronger.
    • Like Like x 1
  11. WC1
    WC1 Active Member
    Hi Dave, I always thought brass was softer, maybe because I usually cam out the brass slots but then I am a self confessed ham fisted vegetarian!
    I bow to your superior knowledge.
  12. falable
    falable New Member
    i was planning to use a jabsaw and tear into the wall to find the joist, then mark it and patch repair. what do you think?
  13. falable
    falable New Member
    hi, i've been using bnq and screwfix for plumbing supplies. should i continue or replace?
  14. falable
    falable New Member
    so should i throw away the fixings supplied?
    also could you send me a link on suitable brass screws?
  15. Rob Foster
    I would use a claw or ball peen hammer to knock dainty holes in the wall after I had used a slim screwdriver to locate the studwork and maybe a noggin.
    This way you might not damage a cable in the wall. centralheatking
    • Useful Useful x 1
Loading...
Similar Threads - advice installing basin Forum Date
Worcester 24cdi problems, advice please!! Central Heating Forum Wednesday at 9:57 PM
COMBIMATE Dripping any advice Plumbing Forum Tuesday at 6:47 PM
