Discuss Air Source Heat Pump or Gas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi hopefully be moving into a new 60’s 3bed semi. Currently has no gas main and only storage heaters. so been looking at air source heat pumps & central heating etc as an alternative to getting gas main, combi and central heating. Looking for some advise on best solution around costings and suitability for the property. I don’t have a bottomless pit of money and can’t seem to find some rough pricing around the heat pumps.
Any advice would be great and if you need anymore info let me know.
Cheers
Heat pumps are more suited to new build with very high level of insulation and very low heat loss.
Due to the low output water temperature they're also more suited to underfloor heating.
I doubt you'll get anyone to quote to fit a heat pump into a 1960's property and guarantee comfortable temperatures.
If your limitation is money then its gas due to age of your property but as for running cost regardless of what system you have the thermal losses of the building will be the same if you don't address that first, which is more important for a heat pump. There are high temp heat pumps which qualify for a FIT that will match the running costs of gas with the payback without the need for a gas supply to pay for and wouldn't cost much more than gas as its from scratch
There is no such thing as a free lunch with renewables. The investment is very high with a long and totally justifyabke pay
back period. Also we tell the truth here so dont get sucked in by some micky mouse sales person for an air source or ground source set up. Bite the bullet and dash for gas, do,it now prices are cheap until central heating season September on
Cheers fellas
Was leaning more towards gas to be fair.
Was just thinking about saving the planet on my own haha.
Will head over to the heating boards and try and get some advice around systems and boilers.
Reply to Air Source Heat Pump or Gas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be the same as with my oil boiler and water storage tank (gravity-fed)?
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t look well piped , kinky in pipes in some places ,some of the rad don’t heat up too well , probably because of the badly piped system, the pipe is all...
  • Article
The UK Government has today been told to do better when it comes to Heat Pumps and Hydrogen Boilers. A watchdog for spending has said that the Government in the UK needs to do more to make green energy heat pumps and other green central heating options more affordable for the UK customers...
hi everybody i need some help please, i can't remember how to adjust the temperature setting in heat mode on my dream air source heat pump does anyone know the sequence please? any information would be much appreciated .
2K
Mike marks
M
