- Messages
- 359
Recently went to house for CP12- and I had a while you are here could you look at....
Mixer taps in bathroom and all pipework boxed in good n proper. mmm scratch scratch ...
ok disconnected cold supply to CWSC and temp connected to cold supplying bathroom,
( basin bath + loo ...) water on NO PROBLEM so no blockage.
Reconnect and same problem no flow.
Then made a permanent connection, cold now on mains pressure. Super as shower is electric anyway.
After this I wanted to know why and how come, so I asked around.
Then someone told me about aeration. This is when - correct me if I'm wrong - a ball valve - likely loo, no longer seals when 'off ' and air is sucked in, making the flow low? or creating an air lock...
My questions: r this - if this is the case should I go back to the property and change the wc ball valve washer , will it affect the water now that the cold is on mains- i.e. is this a bad thing? AND how can you test if it aeration happening - for future ref ..
never heard of this before so am puzzled and for any one shedding light ...
you are a diamond!! :devilish:
- :crazy:
