Discuss advice on fitting a new tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do you have a hot water cylinder with a big tank in the loft?
These will do the trick, and don't forget your inserts
https://www.NoLinkingToThis/p/hep2o...1pcsDyULAu6EUT_jHYAaAkzREALw_wcB&gclsrc=aw.ds
Thanks, basically the copper pipe is attached to current taps which would be replaced by the flexi pipe that i've attached.
I wouldn’t recommend that. But that’s just my personal opinion.But If you cut the copper and install isolation valves you can install the flexible pipe on to the isolation valve.
These look interestingThese will do the trick, and don't forget your inserts
Reply to advice on fitting a new tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
