Discuss ADEY magnacleanse unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
shyguy2005
Hi Guys,
Been looking at these units “ADEY magnacleanse “ are they decent.
Currently have a standard powerflusher unit.
But like the idea of doing a hot flush with ADEY unit and seems quicker.
Any advice would be greatly appreciated.
Cheers
there great all i use
Np getting driving today :D
I have to say. They are good but I like the combimag because of the ease of the bypass for emptying. Magnacleanse is still a great product
Magnacleanse looks great. But why can’t we just use an existing filter to take the magnetite out?
I mean add your chemicals, turn each rad off in turn, it all goes through the return and through the filter.
I know you get two large magnets with the unit and it may well be quicker, but then again I’m saving myself £450 so seems to make sense.
The small / normal one would get filled up in minutes when cleaning
I’m not really sure how you figure that 40-50 times. All the videos I’ve seen on YouTube, there’s not really that much sludge coming out. Or to look st it another way the two large magnets are 4 times the size of a normal size one. If you empty the large magnets once, then your emptying a normal size magnet 4 times.
It’s all relative mate depends how dirty the system is. If your cunning you could pipe a bypass for the magnacleanse and keep the water circulating while you empty the magnet chambers. If you just use a magnaclean you’ll have to stop everything empty the filter put it all back together losing heat and circulation. Utter waste of time. If you’re doing a proper flush it should take a proper amount of time. I don’t believe that a magnacleanse will do it in the time quoted on a dirty system So a magnaclean will be even slower
I do respect your points of view, having used the magnecleanse you have one up on me in that regard. However I just can’t help but feel that the publicity that system cleanliness gets within industry, presents a fantastic opportunity for companies such as Adey to take advantage of legislation to make an awful lot of money.
Also, and as a completely separate point. I find it a hard sell to customers living in my area (S. Wales) generally speaking people really don’t care how clean there system is, as long as it works they are happy. Customers are going to have to buy replacement rads anyway, so it actually works out more cost effective for them to buy new rads (a few at a time) than pay for flushing.
Yes but we’re also talking cleanliness for a new boiler and no warranty. I’m sorry mate but I completely disagree with you it’s not a hard sell its installing as per manufacturers requirements and not making a headache for yourself when the customers new boiler packs up. You try and do a flush with a magnaclean. See how long it takes you. On a side note I use a kamco powerflush and combimag same principle but you can do a system of tar back to spotless in a day. It’s about using the right tools for the job in my opinion. Not having a go just how I work
Look seriously mate, I know you say some of your customers don’t give a toss but I work in some multimillion pound houses and the customer expects you to have the right gear to do it efficiently and correctly. As I said not having a go but I’ve always been taught to use the right tools for the job. Seriously have a go doing a flush with a magnaclean and see how long you’re there
Well there’s your difference isn’t it. You’re working for wealthy people who don’t mind spending the money. This gives you the means to re-invest in your business by buying the right tools.
Trust me around here installers tend to employ the ‘3 F’s’ of Boiler install. ‘Fit, fire up and uck off’.
Reply to ADEY magnacleanse unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
