Discuss Power flushing 1 pipe system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher buzzard
hey,
Set up - 3 storey house. Boiler in cellar, sealed system. Ground floor 2 pipe system, the rest of the house is 1 pipe. 2 radiators and 2 towel rails are no longer heating up. Approx 16 radiators in total.
So after fitting a new boiler, running system with cleaner in for a day. Hot flush. Cold flush. Left at night with all radiators heating. Got a call 2day to say 4 radiators aren't heating up. So balanced system on lock shields, still nothing. Even turning off all radiators, leaving the 4 on did nothing. It's just seems to be circulating on the 1 pipe system not entering the radiators back to the boiler. Pulled some water of the radiators, which after a time produced hot water. Both valves on the radiators are very old. But isolating the rad and opening both valves produced water. All be it very black. So the valves are allowing water to flow. I've decided to go back on Monday to powerflush the system. So my question is how can I do this. Powerflushed 2 pipe systems many times but not 1 pipe. How do I stop it circulating around the pipework and into the radiators.
Thanks for your time.
did it work before you installed the new boiler?
I was told that you cannot powerflush a one pipe. It will not clean it properly?? But I have been wrong before?
Not very good anway you really can only do the main run and not to the rads
I was thinking that. Yes they all worked so the owner said. Although I never checked them before because I had no reason to. The boilers flue had rotted away and no spares so had to replace boiler. But think maybe it's the 1st time it's been drained down in like 10 years. No fernox/filter ect. So proberly powerflushing will be wasting my time? Any other ideas? I've changed the pump with one I had on the van to see if it makes any difference over the weekend. Here's hoping!
Have you tried turning all the other rads off eg the two pipe circuits
Yer one pipe system it will just whizz round the pipe without entering the rad.
Unless you install a gate valve in between the two tees of the rad for each rad o_O ha
But that’s just madness haha
Yeah sealed for 10+ years. The water from the initial drain down seemed pretty clear. Yes had all the rads turned off apart from the 4. It was returning back to the boiler fine. Just not through the radiators. Tiled floors in the rooms where the radiators aren't heating up. Nightmare!
The rads on a one pipe work by gravity so no, you can't powerflush them. You will need to take them outside and hose them out.
Are the valves getting warm?
If they are it will be some sort of restriction on the branches or in the rads.
Are the rad valves the correct type?
If you have normal rad valves designed for a two pipe system installed on the one pipe system, they may not allow enough of a gravity flow out of the rad.
age old worked fine before you came, 10-1 they didnt work fine but you are stymied i would go down the routs of cleaning th e4 out individually and also running through the valves if one pipe they nee to be full bore so if trv's they may be the wrong ones.
hey,
i have had this many times and come to the conclusion its a waste of time the only way to clean rads on a one pipe is to take them off and flush them individually
One pipe systems work best with swept tees and trv in Let at the top of rad and locks bottom of rad.
But as much as you want to say “well yer it worked before so it has to work again now” it’s a old system that is not to manufacture instructions. You won’t find in the MI a onepipe system.
Get it upgraded
Reply to Power flushing 1 pipe system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
