Discuss Press fit machine purchase in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gingalig
Hi, and thanks for any advice before I start, I'm looking to buy a press fit machine but getting a bit bogged down in detail.
Questions I would like to know the answers too are:-
. Who is the best supplier of fittings.
. Which fittings to use and are the best price/ quality wise ( definatley confusing me this one).
. What's the most practical/ cost effective machine. In terms of access, weight, use etc.
. Am I right in thinking M profile tongs for Gas and Water.
My main work will be 15mm 22mm and 28mm and it's a combination of gas and water works (although not in the same pipes :) obs )
Any thought and first hand experience greatly appreciated. Apologies if it's been gone over before.
Pipekit and bss
Geberit are the best and x press are 2nd
Novopress aco 102/102
M are the fitting profile what they recommend for warranty etc
Yes also if you would like if your on new build mlcp will work with the tool just need a new set of jaws u profile etc
I tend to stick to Mapress and their machine. I hire the machine because it's expensive as you know. Why don't you do that and put the cost on the customer until you decide whether you like it or not. In my opinion there are for's and against's and I remain undecided. If it's a relativity small job, I still get the Rigid out.
Love the smell of Boss white in a Morning.
. Which fittings to use and are the best price/ quality wise ( definitely confusing me this one).
Have you made a decision on this Gingalig?
Personally just hire from Bss as previously mentioned.. also I believe they require re-calibrating every so many thousand crimps.
Whether that can be done ‘in house’ I’m not sure of
We had to do a repair in an 100mm copper fire service last week.
Used slip couplings.
Cut the insert pipe, measured the section of pipe to cut out, cut the pipe and press fitted the fittings.
That took all of 5 minutes.
Re-commissioning took 4 hours
Reply to Press fit machine purchase in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hello everyone, I am new to the forum, thanks for having me. Tomorrow I am getting an ATAG i28C installed but, unfortunately, the gas engineer...
2K
Hi, and thanks for any advice before I start, I'm looking to buy a press fit machine but getting a bit bogged down in detail, I have searched the...
16K
Anglia Pipe Tools Ltd
A
Hi I'm looking for advice in the hope that a kind & knowledgeable soul (or two) may be able to assist. I'm looking to replace two basin mixer...
1K
    • Informative
A month or so ago I asked on here about the pros and cons of press fitting and I said that I'd post a review after using it for a while. I...
10K
