Discuss Outside tap screw query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
on an outside tap what is the reason for the small screw underneath the tap body.
If it's got a little plug/screw in the check valve it's a verifiable one.
Reply to Outside tap screw query in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’ve lost the pressure from the outside tap. It was working fine. I have checked the washer on the outside tap and the inside stop valve seen in the picture. Not sure what the thing is to the right of the stopcock? I’ve also taken the inners out of the outside tap and turned on the water again...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and the compression joint where the pipe enters an isolation valve now leaks. The outside tap was covered for the winter by an insulating blanket. I...
My outside tap has had really low pressure after the cold weather a few weeks ago. Its connected from under the kitchen sink, and can be isolated from turning a flat head screw type thing a quarter turn. Any help or advice would be much appreciated!
Hi all I'm having an issue with my outside tap not working, the tiniest of dribbles comes put each time I try it. Ive changed the tap to no avail so thinking I should change the stopcock tap thing under the sink? Please see attached photos. Many thanks for and advice. Cheers Gary
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
