Discuss How to close this valve. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gary
hattersley valve.pngI am working on a flat with a communal heating system. i have found the flow and return, one with a gate valve and the other with this valve (below). I know it can be turned of because some time back i saw a service engineer do it. But its in a confined compartment and with it being on the 10th floor i am a little nervous.
Does anyone know how to do it? Many thanks
Sorry it harder than it sounds
BS5451 is for valves, globe and gate but not sure if it covers balancing
Balancing valve, should just screw in, keep count of turns to close and re-open to same position.
You can probably download the MIs and specs from the Hattersley website
Reply to How to close this valve. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rad is leaking from TRV valve, seems to be seeping out of where the pin comes up. I tried tightening up the nut below the pin, but that didn't help. I then looked online and saw that removing the nut and packing with some plumbers tape may help, but whenever I try to remove the nut a load of...
I have TemCon balancing valves fitted on my sits and a questions been asked whether these require servicing. Can't find much info on the manufacturer website so can anyone confirm if they do and if so what level of service is required?
C
I got my regular annual boiler service for my Vaillant ecoTek 930 about a month ago, and the engineer identified that the AAV was leaking, so he closed it. This is a tenanted property and it's not straightforward to get access to it. How risky is it to / how long can I leave the AAV closed...
Cabe F
C
Hi everyone, I've joined the forum today as I've found myself going round in circles with what I think might be a pretty simple problem, hoping someone can help. Our dishwasher is leaking and the manual says this can be fixed by cleaning the water inlet filter. To do this, we need to close the...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small 3rd floor flat, I have a radiator in the front room and one in the hall (very close to each other), there is a drainage valve on one of these. My back...
