Discuss UK Compliant Gas Hob Connection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I purchased a 2nd hand kitchen from Europe and would like the gas hob connected so it is UK compliant. My Plumber had a look and doesn't know where to start. Is there a product available which would make the connection UK compliant. I've attached a picture of the connection.
Any help please !!!
Hi Lee,
A few things to consider:
The main thing you will need is manufacturers instructions to fit a 2nd hand domestic gas appliance in the UK.
Also:
is it suitable for natural gas?
Is there a better photo than just a birds eye view?
Is there a make and model?
Any chance of a better pic of the connector to the hob eg side on
Reply to UK Compliant Gas Hob Connection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’m changing my kitchen and swapping from a gas hob to an electric induction hob. Rest assured, I have no intention of doing any work at all on the gas supply, I just have a question. Assuming we might want to go back to gas at some point in the future, it may be worth leaving an easy...
Hi, Please can someone advise me on the correct replacement parts to re-connect my gas hob? It is an Indesit PIM 640 AS fitted gas hob and the manual states the fitting is a threaded 1/2 gas cyclindrical male attachment. Do I also need to order a fibre washer or o-ring for this? If so which size...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi I've purchased a GROHE | Euphoria 260 Exposed Shower ( looks nice ) however Im missing some initial connecting adapters the installation instructions say it comes with " easy install adapters " and threaded tape ....I have neither of these ,all I have is the " S " unions ... so I did a bit of...
2K
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to you? I suspect that my long ongoing rotting veg/sewage smell is caused by a fault in this connection that has been hidden from previous inspections...
