Discuss Flush pipe connector not fully in. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The flush pipe connector will not fully insert.
The first 2 flanges are completely in, the third partially.
There is not much room between the pipe and the input. When I remove the pipe to check, the connector has not slipped up the pipe. I marked the pipe to ensure it has gone in as far as it can.
No leak on testing but I'm not happy with it sticking out. What do you think?
does it actually fit in all the way / can it eg enough depth
Try some washing up liquid/silicone spray on the inlet not much
Some designer pans esp. italian stuff never seem to fit together properly and this looks typical of this they often do not flush the stuff away effectively either
Centralheatking
I would use silly cone as its waterproof when cured, fairy liquid might just wash away and leak if you have a wickle weep. Thats my opinion after
40 years and many bogs of all sorts fitted
On a 22mm plinth with a mac connector.
Works a treat
You said it was all lined up earlier and looked ok in the photo so why the plinth and a different pan connecter?
Silicone on a flush cone - I hate that, what's wrong with plumbers mait.
Good point, That was supposed to go on another thread.
The soil pipe did not line up, the flush pipe did.
The flush pipe went in with just a little washing up liquid, I have built a brace behind the 90 degree bend that prevents it moving and keeps it inserted. Two of the flanges are completely in, the third is almost completely in, you can just feel the edge of it at the rim, the fourth is flush with the surface.
Reply to Flush pipe connector not fully in. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build boxing to be able to fit the toilet to the wall (this will hold the concealed cistern). I bought a flexi 90deg pan connector for back-to-wall...
Deleted member 120897
I've got a leak at the connector next to the p trap under my bath at point 1. on my attached photo. I unscrewed it and pipe A hardly goes into pipe B - it's almost flush with the start of B. Assume the rubber seal (can't spell) has failed - there's not much chance of water passing through...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3 or 4 ribs on it). It's painted in a fetching pink/purple colour in the photo. Tried to revive it with some grease before inserting a short length of...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet in our new house. It’s eventually going to be moved to the other side of the house. The seal around the back of the toilet had failed so I switched...
I took the boxing out from around this toilet yesterday to find this old style clay(?) or concerete (?) soil pipe. The existing toilet has a 90 deg spigot on the back but obviously the replacement is a nomal modern one. Can I just break the solid seal around the old spigot, whip it out and then...
