Discuss Green star HE 727 servicing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
hi folks. I can’t find any service instructions online for the above boiler. Any advice as to where to find some please folks ? Cheers
Hi Macka,
Sometimes you need a bit more information mate, usually the GC (Gas Council) number of the boiler - or sometimes in the case of Worcester’s the number beginning with 7? - I’ve just found this also if you look at the front of HF link, it’s listing x2 for 7-27. ;) Also not sure if gives details on servicing?
https://www.freeboilermanuals.com/assets/pdf/worcester_bosh/ZWB7-27HE-combi.pdf
Hi Macka,
Cheers mate. I normally get all the details but because I was rushing I completely forgot. You’re right it doesn’t state any servicing details in the book really.
Reply to Green star HE 727 servicing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone, Does anyone know where to find out what size the O rings are in a Mira 723 service kit as I have one (at the pointy end of the piston/spindle) that keeps failing and I cannot afford to keep spending £23 to get one O ring. It is part "G" on the 723 instructions. Any help very...
A
Hi guys I finished my gas course in September can anyone help me i need to do 2 install and services. Am living i ln leeds west yorkshire I do appreciated for any advices . MOD* Please use the forum PM Service to contact members! Thanks!
Ahmad marian
A
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not doing the job but he wants to know what to buy and replace it himself and asked me where to get one. I said I'd have a mooch. He sent this picture. I...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a 35kw system boiler appears to be in 22mm flexible steel pipe (tractpipe, or teslaflex or w/e). Distance from the meter is only 4m-5m or so, and I assume...
Hi folks I’ve got a job today where I’m out in the middle of nowhere and the complaint is water passing into the toilet pan constantly. Now I don’t know what pan/cistern it is so what would you more experienced guys be taking with you please? Also what other items do you keep on the van for...
