Discuss What connector do I need on this shower valve please? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am putting a shower in, but cant fathom what connector I need to use to get the mains water supply connected to the valve.
The water coming into the valve will be via 15mm pipes, but the opening at the moment is bigger than that so I need a reducer or something for this I think.
I'm aiming to connect using speed fit fittings
(See attached image)
Can you advise?
1/2 male iron
This showed up when I searched male iron:
https://www.NoLinkingToThis/p/tecti...e-iron-coupler-15mm-x/784fj?_requestid=450208
I'm not sure it is the right size to screw in though.
Measures around 20mm dia
Inside dia
Reply to What connector do I need on this shower valve please? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
