Discuss Flexible hose advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am trying to fit a wall hung toilet in our new en suite.
The flexible hose within the cistern is only just long enough to exit the hole in the cistern which means the final connection will be very awkward.
The flexible hose is female BSP both ends. One end is 1/2" to fit onto a 15mm isolating valve and I'm guessing the other end is 3/8" but I'm unsure all I know is it is smaller.
I don't seem to be able to find any replacement hoses in 500mm length.
Any help much aporeciated.
obviously yours maybe different but every wall hung toilet iv done the flexy hose in the cistern stays in the cistern and threads on/in to there 90 degree shutoff valve which goes into the "hole" your talking about and then to the float valve ,
Reply to Flexible hose advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
