Discuss Need help removing bathroom mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
I need to replace my bathroom sink mixer tap but can't remove it from the sink for the life of me.
I've uploaded a few pictures of the tap from various angles. There doesn't seem to be any screws or allen key points.
Has anyone seen a tap like this before and knows how to remove it?
Many thanks
Matt
Hi there,
Many thanks
Matt
Underneath at the rear will be
usually a couple of flexi hoses supplying live
hot and cold which will need isolating. Then there will be a hexagonal long nut which can be undone using a flat head screwdriver usually, then you can withdraw the assembly from the top. Centralheatking
you can use a mirror to check otherwise do as RPM
suggests
Reply to Need help removing bathroom mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
