Discuss How to change a water filter cartridge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I was wondering if anyone can give me simple instructions of how to change an Acquifier water filter cartridge?
I believe I have to turn the water off first, under the sink, and need to locate a quarter turn valve.
I was wondering if anyone can help me locate this valve or a point under the sink where I switch off water so I can replace the cartridge.
I assume I also need to switch off the mains water point.
H under sink water cartridge.jpg ere is an image of under the sink - the think blue piping leads to the cartridge that needs to be replaced.
Thank you!
It will be fed from the mains water supply, so just turn that off if you canā€™t find a valve locally. Either st your stopcock or out in the street.
You can try turning the washing machine valve off that feeds the filter sometimes they work sometimes they stick if not as Ben says mains off etc
or open your filter tap and turn the valve off if it stops your good to go as harv says have a towel ready for any drips etc
Many thanks all. This is really helpful. I shall try the suggestions and certainly turn off at mains. I can't see anything understeer sink that I would need to switch off. I assumed I would need to turn off a valve here but don't know what I'm looking for....I hope that turning off at mains would suffice and then do a quick filter replacement. ..
That's really fantastic JC. Brilliant . Many thanks. It's much appreciated. I shall give the valve a turn bit will switch off at mains as extra precaution. :D:)
Reply to How to change a water filter cartridge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
