Discuss Language Setting Problem - Vaillant Ecotec Plus 824 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dear All
Help! My boilers settings are in Polish and the manual online has a different settings box to mine (cf picture). I have tried google translating the options that come up but none of the words translate to 'language' in English. Help greatly appreciated.
Best
Joan
Does this help ...
If you unintentionally select a language that you
cannot understand, you can change it again as
described below.
> Press the right selector button and the plus button
simultaneously and hold them down.
> Press the fault clearance key for a short time.
> Keep the right selector button and the plus button
pressed until the option for changing the language
appears on the display.
> Select the language of your choice using the minus key
or the plus key.
> Confirm the change by pressing the right-hand selector
button ("OK"
Reply to Language Setting Problem - Vaillant Ecotec Plus 824 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
