Discuss Kitchen discharging into rainwater via bathroom drain in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, getting a big renovation done in a tenement flat in Scotland, my builder has connected the kitchen drainage into the bathroom drainage all discharging into one pipe which feeds into an existing branch of the rainwater pipe. All the flats bathrooms lead to this pipe. Aside from the fact my drawings state that a new branch to the soil pipe was to be created for the kitchen, is it against building regs to do this and will having them all connected cause me problems? Particularly in heavy rain?
Ta,Gordon
Don’t know regs for Scotland, but it doesn’t sound like a good idea anyway - how big is said pipe? If it’s six inch for example then I’m sure it would function ok, but then again you do get a lot of heavy rain.....
Thanks, that's helpful. Im possibly even more concerned about everything for the whole flat going out through one standard pipe.
In the attached my old kitchen used to be attached to the branch marked green, everything is now attached to the branch marked in orange, all bathroom and kitchen discharge there and in my drawings the new kitchen was meant to connect to the svp marked blue.
Will one pipe cope if I empty a bath while running the dishwasher and washing machine for e.g?
Ta
Reply to Kitchen discharging into rainwater via bathroom drain in the Plumbing Jobs | The Job-board area at PlumbersForums.net
First of all, apologies, it seems this topic has been posted but don't believe my specific issue is covered. So been living in my Victorian house for almost 10 years, no issues. Have 2 bathrooms, 2 loos that all go to a large underground soakaway, I believe. I can only see one soil vent pipe...
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed supply and all 6 in the block have a shared rising main pipe (I think unless there is meant to be more than one). Kitchen: From the ground floor to...
I am working on a remodeling a kitchen in a single story house with crawl space that was built in the 1950's. I was wondering if there is a better way to plumb the drain lines that are in the attached picture? There is a bathroom sink drain directly behind the wall of the kitchen. The white...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi all, I would really appreciate your eyes on these pictures - What do you see ? Does anything look strange about the Rockwool insulation to you? I suspect that my long ongoing rotting veg/sewage smell is caused by a fault in this connection that has been hidden from previous inspections...
